1990 D250 Front Brake Rotor Question
Old 01-25-2014 | 01:56 PM
rrgrassi's Avatar
It is time to replace the front rotor on my D250. The truck has the hub/rotor as one cast piece. The parts houses are showing it to be a two piece set up.
Is there an updated set up I am not aware of?
Thanks!
Old 01-25-2014 | 04:20 PM
maybe368's Avatar
Thanks!
Apparently it's a mixed bag, rockauto shows both, with this one being 1 piece...Mark
Old 01-25-2014 | 04:34 PM
rrgrassi's Avatar
I found a single cast AC Delco listed for the 4000 lb axle. A two piece can be easiers to work on, provided that are bolted to the hub from the back like my old MB. Having either/or is just crazy.
Old 01-26-2014 | 12:17 AM
Jim5870's Avatar
Use D350 brake pads as an upgrade
Old 01-26-2014 | 12:22 AM
Are you sure you can't pound out the studs? I know they appear to be a one piece...but they should come apart. If the studs coming through the rotor are "staked" on the front side of the rotor...small punches set 90* apart around the base of the stud...then it's a one piece rotor. Other wise you just need to hammer out the old studs....then replace the rotor...And hammer back in the old studs.
Old 01-26-2014 | 08:32 AM
mknittle's Avatar
Mine are the 2pice and it is a 90 D250.
stillsmokin209
12-24-2019 05:54 PM
acbarnfinds
11-12-2014 09:03 AM
stillsmokin209
07-01-2011 11:31 PM
NewOldTruck
02-03-2011 09:43 PM
RAM2940
11-30-2005 08:28 PM
