14mm Pump Mod
Why is there so much aversion amongst most of the first genners to doing the p-pump swap? Assuming you, or someone you know, can do the swap the right way, why not? Is it just the challenge of trying to make more power with the smaller pump?
Chris
Chris
There's a staunch originality cult in every vehicle enthusiast group I've ever seen that cannot tolerate anything "un"original on their cars, trucks, whatever. This mindset is driven by resale value in the collector vehicle market. They are only in it for the money. They will typiclly deny this to the bitter end, citing love of the cars, etc. but that is mostly B$. They are just driving up the prices trying to make more money in the market.
Personally, I have never seen a vehicle that was so perfect or near perfect in every way that it could not be impoved by some aftermarket or custom mod, so I'm all for it. Whatever makes the vehicle better in the owner's eyes is great AFAIK. Nobody else matters. Just my humble opinion...
I am not saying the p pump is not great, it is, but it is also a huge time consuming challenging install. You need a lot of very costly parts and the donar truck to get them. I am also not sure if your average shade tree mechanic would be comfortable doing it. I would like a cheaper easier alternative. I do not however want reliablility problems. The BD turbo I just recieved is 1/2 of their twin kit. I will need more fuel supply to feed these however. If the 14mm head can be made reliable then I think this would be a great mod. If this can not be made reliable then I will move on.
If you want the top power out of a machanical pump, the the p pump is it hands down!
My self i like the "bump" and it's started!
Being able to take off and drive it ammediately, were as the p pump keep you there for awhile,and thats no evan in cold wether.
cheeper parts when you want to up grade(3200 spring,fuel plate compaired to a turn of a screw! )
just my o2
just my o2
I know the inline pumps are more expensive to add than a 14mm head and can take a lot more work to get the whole system tuned in properly after the swap. I can understand those people limited by a certain budget not wanting to do the swap, and I can respect the guys trying to get all they can out of the rotary just for the sake of doing it. It just seems like a lot of first genners treat the p-pump conversion as sacrilege (not directing this at the guy above, as I understand that comment was made in jest). I don't know - to each his own, I guess .
Chris
Yeah, that is where it becomes a really big deal in the muscle car market with aution prices reaching outgrageous levels in the past few years. It is really no issue with our trucks. But as you saw, the tone is still there somewhere, despite the fact that it is obviously a non-issue.
Well as far as hp goes, the p pump is king, I like the ve as much as u guys do. I was always wanted more an more out of the ve relieing just on fuel alone to lube the pump is the death of the 14mm pumps. The pump has such a high volume they run out of fuel an choke. I hope KTA has good luck getting them to hold, In the long run the p pump is cheaper for now.
there definely comes a time when you have to throw a lot $$$to stay on this side of the fence,... and push it or ....throw a lot of $$$ to get over the fence.
Hope i don't ever have to make that decision!
The only way I would switch to the P-pump is if the motor blew up. Then I would look for a 2nd gen 12 valve to transplant.
Would it be better to run an inline 12v Hi Perf fuel pump. I think this may supply a larger volume of fuel which is what people are saying the problem is. Is this possible if used w/a presure regulator.
I think they can be reliable with the right set up. You need allot of fuel going to the ijection pump to keep it alive. Just because you can get the fuel it doesnt mean that you can make big numebrs. Bill is a perfect example of this. You have to have the right combination to make big numbers.
500hp with water/meth is no problem you could do that with a stock pump. If you have the air to burn it. I could gain 100hp with a stock pump when I hit the water/meth.
I just built a nice stock pump that should be close to 500hp on #2. It might even be over. I still need to put it on and do some testing. When it was on the test stand it actually supprized me.
Stomp
Stomp
I respect your reply as I envy the numbers you are laying down. As stated earlier my turbo is part of BD's twin kit which I will be purchasing.(eventually, this Cummins is getting expensive ) I want to make sure the fuel is there. In your opinion for the 500rwhp is it necisary for the 14mm head or is it better to just tweak mine(non ic) and use the piston lift pump(on order w/lines,etc.). If you have a recomendation please feel free to share it with us.
All others, keep up the replys as all information is great.
Stomp
The 14mm will make it easier to make 500hp, but I was just trying to get accross that you dont have to have it to make 500hp. With the right set up it can be done. Who really cares if its at 400-425hp on #2, but then when you hit the switch it goes to 500-525 with the water/meth. It is still fun to drive and all you have to do is hit the switch.
Stomp
Any one else know if the elecric pump is a good idea? If so can I just fab a cover for the lift pump hole? I am still not sure about the 14mm mod but regardless a solid flow of fuel to any injection pump cant be a bad thing.
