12cm is on
It must be the 5 speed, I have an almost identical setup (pods,hybrid ex.) except for the mushy 518 and I can barely crack 1100F...either that or my inj pump is REAL tired.
Originally Posted by JustRamIt91
nice, did you have a chance to test it out yet?
3rd gear is amazing now, 4th gear going about 35mph through town is still extremely smokey when you floor it but that's to be expected as 4th gear is kinda deep for 35mph
Originally Posted by Subliminal
Hey Crossy...
Before you installed it, did you find any good write-ups, or was the install pretty self explanatory?
Today 04:50 PM
Today 04:50 PM
Wasn't too hard.
All i had to do to the downpipe was loosen it from the bellhouse and wire it back until i got the housing on, the housing is about an inch longer than the stock one so downpipe has to move back one way or another,, it kinda pushed the tailpipe back about an inch and now points up a little at the body but oh well i'll probably loosen the tailpipe and move it so it sits level again.
The turbo is still really quiet though...hopefully it's becuase of the stock intake and stock air filter......
The HX35 is a good easy upgrade but severely limited on the air flow.
With a little more work an HE351CW or HE351VE will provide even more bang for the buck, almost instantaneous spool and +40 psi on a whim. Much better air in the mid-range where its needed.
I think a 12mm would melt my pistons by the time I hit 80.
On what are you basing that? The 7-blade version is mapped to 60 pounds/minute...which is a 10 lb./min increase over the 8-blade. The later ones( the 351's ) are better, and slightly more efficient, but are they that big a leap over the HX35 like the 7-blade is to the H1C?
cheers,
Douglas
hey-Hey!!!,
cheers,
Douglas
cheers,
Douglas
So I'm swapping my housing as I type. Man, what a...fun endevour.
So I got the thing off, and started working on the exhaust housing bolts. 2 of them came out easily...two of them came out after a few hours of banging on them with a chisel and braking the heads off. GRR!
And of course, once I got them off...the housing won't separate from the center section.
Shoot me in the face.
Crossy...you wanna come over here and handle this action for me?
