12 valve
12 valve
I have an 89 first gen, it's intercooled, has a fuel pin, I advanced my timing, pump is turned up, cold air. What are some other things I can do to it? I know injectors but I'm not sure what else I can do.
It wouldn't be intercooled from the factory….did you install a Intercooler, if so what do you install?
Is the block still a '89 NON intercooled motor?
I ask as the earlier NON intercooled motor come with a much bigger injector from the factory, so I tune one differently than the other….
So you have the earlier motor with the bigger injectors in it already.
Those should be good then.
You could throw a 366 spring at it to let it rev a little more.
Do you have a pyro and boost gauge?
If so what sort of #s are you getting at WOT?
A HX35 turbo is a bolt on. Used ones are pretty reasonably priced.(most of the time)
05-17-2003 03:28 PM
phildog
04-02-2003 05:44 AM
