1/2" wheel studs and Rickson aluminum wheels?
I have a set of 19.5 aluminum Rickson wheels on my D250. When I purchased my tires from the local shop and had them mounted, they installed some aftermarket lugs and center caps. I'd like to dress her up with the 2nd Gen center caps. This requires the 2nd Gen lug nut which requires a 9/16" wheel stud. The studs also need to be a bit longer. So, I'm having trouble locating the correct wheel studs. Any ideas?
Dodge has a Lug nut for this. Its a 2nd gen lug nut with 1/2 threads. The # is on the site hopefully someone will chime in or you can locate it. I'll see if I can locate it since I had it written down a few months ago.
FYI Those dodge 1/2 inch shouldered lug nuts that worked on my stamped steel rims for the 2nd gen hubcaps do *NOT* work with the ford alcoa 16" wheels NOR the 19.5 Ricksons!! Ask me how I know this...
royta
04-04-2010 11:31 PM
hipsi
03-10-2008 03:48 PM
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
