01 flywheel same as 93 ?
Old 02-18-2010 | 01:42 PM
Will a stock flywheel from a 2001 cummins 6spd work in a 93 getrag truck?
He only wants $50 for it, he replaced with a southbend flywheel.
Thanks
Old 02-18-2010 | 02:25 PM
jimbo486's Avatar
yup! just need the 3/4" starter spacer. the getrag has a 13" clutch as well, so i would imagine the pressure plate assembly will match the bolt pattern. i wouldn't know for sure though since my clutch is from an '01. well, not anymore. got the southbend installed on monday
Old 02-18-2010 | 02:52 PM
Your post confuses me.
I'm gonna need a starter spacer to use an 01 flywheel in a 93?? whats so different??
I just need an extra flywheel to send out to the machine shop, but meanwhile keep the truck on the road until the very last second.
I measured from the center of the flywheel to the outside and its 13" and i can see where the old clutch was heating it up and it was for sure a 13" clutch that was on this flywheel. Told its from a 2001 6 speed cummins. Guy lives right around the corner from me.
I'm using a 1st gen clutch, 1st gen everything besides the flywheel i hope.
Old 02-18-2010 | 03:07 PM
JD730's Avatar
Um, the starter spacer will not work, 1st gen and 2nd gen starter have different bolt patterns, only 2 holes line up between them, would work in a pinch, but I wouldn't get in the habit of it.
Brandon,
Are you going to reuse the pressure plate or get a new one? The Sachs style pressure plate is made to go on the matching flywheel that has a slight lip around the outside where the pressure plate sits into. Or are you going to go with a new style pressure plate? If you need dimensions I have 2 complete Sachs style setups in the shop.
Old 02-18-2010 | 03:30 PM
Its a Valair performance clutch kit i got, with pressure plate. 3400#
The clutch is 13" made for 89-93 getrag trucks. I was just hoping this 01 flywheel will work since its a good deal and its 2 blocks from my house.
Maybe i could ask Valair?
Old 02-18-2010 | 03:38 PM
1bad93's Avatar
i belive when i ordered my south bend it said it worked for any truck up to 01.
Old 02-25-2010 | 02:24 PM
Does anyone know for sure??? i was thinking about calling southbend or something.
Old 02-25-2010 | 04:42 PM
jimbo486's Avatar
i'd say give peter a call at SB.
Old 02-26-2010 | 01:37 AM
TPD1990's Avatar
sbc fits all 5&6 speeds 89-05
so yes it will work
Old 02-26-2010 | 10:42 AM
Thank you sir.
Old 02-26-2010 | 03:48 PM
TPD1990's Avatar
your welcome
Old 02-26-2010 | 08:52 PM
texastuff's Avatar
the getrag flywheels had a lip on them that aligned the pressure plate, If your flywheel doesnt have a lip, the 89-93 clutch wont work. you better call a clutch manufacturer and find out for sure.
Jona Gold
27
01-03-2024 07:54 AM
oliver foster
06-05-2010 01:47 PM
J Lent
60
11-03-2009 09:14 PM
jmccart
01-18-2007 03:26 PM
Quick Reply: 01 flywheel same as 93 ?
