[B]KDP praise, and questions[/B]
First off I wanna say Thank You Very much to just about anyone who contributed to anything KDP related. A couple ideas I found EXTREMELY helpful are,
#1, The "Whack the Fan nut with a punch" idea, it worked like a champ for me, and as stated a couple of whacks and it was loose, no wrench needed.
#2 "The cardboard bolt map" For the bolts holding on the timing cover. Most bolts are the same size, but there are a few that are longer, and of course if you're like me you'll forget where the long one's go when it's time to reassemble!
FWIW, I removed my radiator prior to doing the KDP, I know it's a *****, but your knuckles will thank you!
Now, onto the questions. First off when I pulled the timing cover I noticed that on the crank snout that there are a couple of grooves. I can feel them when I rub my finger over them, so that tells me they are reasonably deep. Is this normal or something to be alarmed about?
Next, I noticed that my crank sensor seems worn on one side. Obviously it was way too close. Add to the fact the truck has a bajillion oil leaks letting the balancer collect oil, dust, dirt, grass seed, etc then in turn rubbing the crank sensor. Question is, should I replace the sensor or might it be fine?
Thanks again for all your help!
I'll try to post a few pics in my gallery
I would replace the sensor while you're in there. The gap should be set to 0.050 with a non-ferrous feeler gauge.
The grooves are likely to cause the new seal to leak. There is a seal and sleeve kit available to fix the grooves.
Just set your seal a little deeper or less so it will ride in a different position than the old one and it will be fine. If the sensor is working then just readjust it and ride.
I would replace the sence tho.
ddestruel
05-24-2005 08:55 AM
