1998-2002 Dodge Ram 2500 Truck Power Heated Towing Mirror with Support Bracket Pair
Old 07-08-2013 | 01:44 PM
1ATony's Avatar
Vendor - Former Vendor
VISIT US HERE FOR GREAT PRICES 1998-2002 Dodge Ram 2500 Truck Power Heated Towing Mirror with Support Bracket Pair
FREE SHIPPING IN THE LOWER 48 STATES!!
This mirror PAIR with support brackets is a direct replacement of the original fold out style tow mirror. The Mirror rotates 90 degrees from a horizontal orientation, to a vertical orientation that gives you a better angle of sight for towing a trailer.
You can also upgrade a standard style power heated mirror with this mirror PAIR if you desire more vision when towing. Some applications may require the re-use of your mounting studs. These mirrors come with long mounting studs like the original application.
Mirror specifications:
Comes as a PAIR
Fits both the LH (Driver) & RH (Passenger) Sides
Power
Heated
Folding - Can lay flat against the door
10X7 glass size
Replaces dealer part number: 55076488AE, K55156129AC, 55156129AC, 55076489AE, K55156128AC, 55156128AC
Measures approximately 18" long folded in and 24" long folded out from base
Direct replacement
Injection molded textured black plastic housing
Built to strict quality control standards
INCLUDES mounting brackets*
Please CLICK HERE to see wiring routing instruction sheet so as not to pinch mirror wiring harness.
*PLEASE NOTE: If your vehicle did not come with this mirror pair originally and it is being purchased as an upgrade, the included reinforcement mounting brackets will have to be used to allow the mirror pair to work properly.
Installation Note:
Use caution when installing mirror not to pinch wires near mounting area. Pinched wires can result in shorting.
These mirrors are a direct bolt on replacement to your original mirrors.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
Old 07-26-2013 | 09:55 AM
Numidian's Avatar
Do these plug into the factory harness for mirror adjustment and defrost?
Old 07-26-2013 | 09:58 AM
1ATony's Avatar
Yes, If you match your factory options to the tow mirror options such as heated,power, turn signal etc. they will plug right in and function properly. You do not need to splice anything.
Tony
Quick Reply: 1998-2002 Dodge Ram 2500 Truck Power Heated Towing Mirror with Support Bracket Pair
