Will edge juice attitude give u 180 HP?
I have a 2004.4 ram diesel. I am in process of waiting for my edge juice attitude with hot unlock. If i set attitude to HOT unlock and run a intake like ****** whistler and delete cat and stock muffler, will i see 500 engine HP over the stock 325 HP?
You have to remember one thing about that 325 rating, it's at the crank, not the rear tires. The Juice will most likely give you the 180 at the tires but you'll still be a little short.
thats what i mean. i know 325 is at the crank. and edge boasts that hot unlock will raise crank HP up 180. So 325 + 180 =505 Crank HP. either way you look at it i will be gaining 180 HP right. so if my rwhp now is 250 it will go up to 430 rwhp. right?
And why wouldnt i have enough fuel. the edge will give me more fuel thats what it does.
Need a new LP, Exhaust, and tranny you will probably see 430Hp at the wheels. Look at MadHat's numbers you will be close to that. He has an MP-8 where you will not.
it does add fuel but, if it is asking for more fuel than your stock system can deliver then you will end up draining the rail and not making the power that you should
One of the most commonly used pressure boxes ever sold. Stacks great with just about anything as long as it doesn't add pressure. As for the fuel issue these guys are talking about...... they aren't saying you will need more fueling to make more power; they are saying you will need more fuel to support the Hot Juice. In other words, a new lift pump system like a Walbro, FASS, or AirDog setup.
