Will 35" tires fit??
Old 09-20-2008 | 04:15 AM
wl7he's Avatar
Well time for some new tires and I was thinking about replacing my 33x12.50x16.5 with a set of 35" tires. Have a 3" lift and have plent of room for the 33's but was wondering if anyone was running 35's without any problems??
Thanks
Old 09-20-2008 | 07:13 AM
ngkefalides's Avatar
you should have just enough room. i put 35x 13.50's on with a 2" levelng kit and just had to do some minor cosmetic trimming in the front to keep them from rubbing but like i said, with a 3" lift, you should be good especially if you aren't planning on running as wide of a tire
Old 09-21-2008 | 10:21 AM
Invalid-Name's Avatar
Yeah you should definetly have enough room, 33's fit under a stock truck with no lift, with a 3" lift you'll have plenty of room for 35's
Old 09-21-2008 | 04:32 PM
wl7he's Avatar
thanks
Thks for the replys, I was pretty sure I would be OK but just wanted to get someone with first hand experience to ease my mind. Again Thanks
Old 09-22-2008 | 09:56 PM
mr_ed's Avatar
From: Ordered to Elizabeth City NC. rather be back in north Idaho
I'm runnin 35's on ten inch wide rims with a 2.5" leveling kit and they only barely rub on the plastic of the inner fender in a sharp turn when I'm on uneven ground...and some slightly longer control arms to get my axle back where it belongs would alleviate that. You'll have no trouble.
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
sakisaki400
23
12-31-2006 10:17 PM
chw
29
08-02-2006 11:31 AM
xyzer
06-22-2006 07:44 AM
Quick Reply: Will 35" tires fit??
