will 2wd 5 speed work in 4wd truck?
I have found a 5 speed from a 2000 2wd truck. I have a 96 auto 4wd.
As I understand it, the speedo sensor is not in the 2000 tranny. can I convert the tranny to accept the speedo sensor as in my 96? or too much work.
tell me if I'm crazy.
lewis
lewis
What about a transfer case or do you just want 2wd??
The year of the truck doesnt matter as much. Its the 2wd or 4wd that causes the problem. Im not sure about 5 speeds but i know that on automatic transmissions that tailhousing has to be changed because of the transfer case. U might also have to change driveshafts because of length.
The 5speed output shaft spline count is 29, plus longer on the 2wd over the 4wd, whereas the automatic output shaft is 23 spline. You'd need a 4wd 5speed and Tcase to swap over.
The trans output speed sensor on the O/D section is only for the governor circuit, to control shift points. Won't need that on the 5speed. Your speedo sensor is on your Tcase on the 96 4WD. So you'd need a similar year model for a 5 speed.
Jordan5687
02-18-2009 02:48 PM
95black2615
10-08-2008 03:34 PM
1320
05-06-2003 06:30 PM
