WHOOPS! Dropped Delivery Valve Washer.
<br>Putting in my 191 delivery valves in my truck tonight. Of course like a meathead I dropped a spring with three little washers. I managed to find the 2 big washers, but the extra thin one is missing in action. Can I put it back together without blowing up my pump? The #4 and #6 springs had 3 washers. The #5 ( the one I dropped will only have 2) <br><br>Common sense tells me without the washer, the spring tension will be less, but how will this effect pump life? <br><br><br>Will my truck just run a little rough? I am going to heading down to Piers on Wednesday...... <br><br><br>HEEEEEEEEEEEEEEEEEELP I need my truck tommorow and for the rest of my life...... <br>
Re:WHOOPS! Dropped Delivery Valve Washer.
I don't know about that but when I put my injectors in I lost one of the thin washers that go on the bottom of the injector so I put 1 bigger on in until I could get a new thin one. The truck was really jerck and wanted to idle up and down when it hit that piston. I would waite or go try to find the washer.<br>DM01
The pump will work with a thin delivery valve washer missing. It will not have the pressure set properly for that injector, so will miss, cough, and create lots of problems. Do not try to run with a thick washer missing, that can lead to injector damage from a major change in displacement volume.
Stake,<br><br> I just dropped it somewhere in the dirt....... I did put it back together the next morning and so far have not suffered or noticed any ill effects. Thanks for the help.
Swamp Donkey,<br><br>I would try to get it fixed when you can because I wonder if the spring tension would change over time without that washer.
John, why do you try to add extra excitement to each bombing project???? ;D<br>I hope you are happy with the 191 DV and good luck with getting the tranny fine tuned. Talk to you later, Marc.
bob95065
14
02-27-2009 11:32 PM
