Where to start - 12v WILL NOT fire cold
Old 01-29-2009, 09:16 AM
~Angry Tractor~'s Avatar
I never heard of anyone using seafoam in a diesel.
Old 01-29-2009, 10:08 AM
John Faughn's Avatar
I have had to do a lot of work on cars & boats , after using lots of seafoam , dissolves fuel hose , diaphragms other rubber like products .
Only heard it use in diesel once or twice .
Old 01-29-2009, 09:34 PM
94ram's Avatar
Originally Posted by TRCM
when it does start, it takes awhile to run on all cylinders, like > 2-3 minutes if you don't raise rpm
what do you mean it takes a while to run on all cylinders?
Old 01-29-2009, 10:32 PM
Fueling around's Avatar
Originally Posted by kas83
Which way are you guys talking about the timing slipping? The timing in my 95 slipped, and was approximately 8* advanced, compared to the ~12.5* stock, and that truck fired up at -25 unplugged when my 97, at 17* timing, didn't start plugged in. It would start at 0 with a touch of the key. That truck had 210k miles, motor never been opened up. Less timing equals better starting.
Make sure the compression is good and that the motor is fresh, and check your fuel system.
I've noticed the same. Truck started much better with stock timing (don't remember the number) in cold temps. With advanced timing it really does not want to run without either block heater or Espar after temps hit about 0° It is even worse with ULSD. EPA not only lowered the sulfur, but also the cetane which you need for cold starts.
BTW, forced aspitation engines do not burn oil as a rule. There is no vacuum to suck oil past the rings or valve stem seals.
Old 01-29-2009, 10:56 PM
94DK107's Avatar
Everyone seems to be eliminating a fuel problem, but a couple years ago my truck had the same symptoms.. plugged in, started fine; cold out and not plugged in it wouldn't start w/out ether and then would smoke and stumble like crazy. After reading this forum, decided I better replace the fuel lines from tank to engine. That cured all my cold start problems and smoke/haze on start-ups.. Good luck
Old 01-29-2009, 11:11 PM
torquefan's Avatar
That was my thought too. I'd have a good look at the fuel return hose at the back of the engine.
Old 01-30-2009, 06:02 PM
TRCM's Avatar
All fuel hoses were replaced from the tank to the engine and back about 1 1/2 years ago using diesel rated hose.
normal fuel pressure is 17-22 @ idle, and 25-30 @ 2500 rpm according to my dodge factory service manual
I have never heard of ANY problems with seafoam and rubber parts.
regarding burning oil, well, it burns blue smoke almost all the time
regarding not running on all cylinders, well, it stumbles and misfires, sometimes even popping thru the exhaust
I highly suspect the oil burning is from to much blow by. This truck has a recycling blow off system on it, the blowby is routed back to the intake
Old 01-30-2009, 08:28 PM
quadstar's Avatar
hard start
you have a intake heater issue. probably your solenoids. Just fixed my 12 valve. did the same things. checked the grid, it was good. even had the voltage drop on the gauge and the wait to stat light on the dash working correctly. My 12 er has 425,000 miles on, leaks a little fuel, and smokes when its cold. I kind of doubt the engine is worn out. My truck has never had the head off, or even had the p7100 apart. as a matter of fact, I finally just changed the valve cover gaskets.
Check the solenoids. Cummins motors are amazing when it comes to durability
Old 01-31-2009, 04:28 PM
patdaly's Avatar
I dunno, neither of mine need grid heaters to fire way past 20 degrees.
Seeder
10-30-2007 12:31 PM
Puke
05-08-2007 10:04 PM
BRUISER
12-12-2006 03:37 PM
loosendend
09-04-2006 12:01 PM
pianotom
06-15-2005 03:34 PM
Quick Reply: Where to start - 12v WILL NOT fire cold
