where does the waist gate actuater hose go
Old 12-27-2011 | 06:08 PM
lenuelmp23's Avatar
I have a hose comming out of the waist gate with a bolt in it.. I know this keeps it closed but where does it go stock? I have no spot on the turbo housing. No tee on fuel pump.
Old 12-27-2011 | 06:25 PM
carl48's Avatar
on the drivers side on the intake manifold on the side there is a 1/8" npt plug it is usually easier if you use a 45* or 90* fitting first
Old 12-27-2011 | 07:45 PM
lenuelmp23's Avatar
Is that where the line from the ip goes in? What way do I route the line from turbo to dr side if engine. I know this sound simple but I want it right
Old 12-28-2011 | 01:47 AM
Tate's Avatar
There is a steel line that runs across the head, from the AFC to the wastegate actuator. Most likely, the tee and line was removed when they plugged the wastegate (which wasn't necessary). To be honest, I'd leave it as is. Unless you're hitting 40+ psi on the stock turbo, wastegating isn't going to benefit you much.
bishgeo
04-16-2008 08:01 PM
ollie32
13
03-01-2007 12:27 PM
dukektm
12-06-2006 01:09 AM
Vanb
03-16-2006 04:18 PM
