Wheel Cylinder Replacement
Well i noticed my rear drivers side brake drum has fluid leaking out of it pretty good. So my first thought is the wheel cylinder is probably bad so i picked a new one up today, my quesion is what all needs to be done in order to replace the old with the new. Thanks mitch@jc
Replace both cylinders with #37337 number good at any autoparts for about $13.
Your drums may be stuck on, easiest way to get them off is to put the rear end on stands, remove tires, put one lug nut back on loosely, start the truck put it in gear then slam on the brakes in forward and reverse.
You will only have to remove one spring to replace the cylinder. I always crack the brake line loose before removing the two bolts.
On a scale of one to five cylinder replacement is at an easy one.
Just one thing to note, the first time I asked for this part number at my local parts store, they gave me Wagner wheel cylinders that looked different, they had the dust boot on the outside, instead of on the inside. Then I went to NAPA, and they gave me the correct ones which have the dust boot on the inside. I'm not sure why the Wagner wheel cylinders are different, or if they even fit, they are correct for a 1-ton Chevy truck.
Gen414
05-07-2009 11:08 AM
cgmorgan06
11-15-2007 04:02 PM
Got Smoke?
05-24-2005 10:27 AM
Journier
11-22-2004 02:56 PM
