what would it take to make 350 hp?
Old 01-26-2012 | 10:56 PM
jayhoo's Avatar
my truck is a crew cab long box 4x4 5 spd with 1500 -3000 LBS in box every day some times i pull a 17 foot boat i live in B.C. canada. big hills all over i dont want lots of black smoke all the time. what do you guys think about gov spring kit 3000 or 4000 and what plate would work best. can i just pinch off the waste gate line?
Old 01-27-2012 | 10:44 AM
9812vram's Avatar
I cooked up this recipe for ya jayhoo! It's what I'd do....
3kgsk
#10 plate
adjustable boost elbow
Tune AFC
Old 01-27-2012 | 03:34 PM
Tate's Avatar
Originally Posted by 9812vram
Hey Tate, I just wanted to clarify your post a wee bit:
The plate's purpose is not to control EGT's, but rather to control fuel quantity. But! - EGT is directly proportional to fuel quantity and air quantity. Sooo..... in a round about way, the plate actually does have a lot of control over EGT's, especially on a truck equipped with a stock turbo. There are only two ways to decrease EGT's - Less fuel or More/Cooler air.....
Originally Posted by lifer
You are correct and so is 9812vram. Where do you think your boost will be when your pulling a load up a hill or taking off from a stop light with load? If you like having to be carfull and have one eye on the egt's all the time then fine, go for it. It only takes a minute or two of forgetfulness and your pistons will be goo.
EGT's can still get high, even with a conservative plate. AFC position and settings are going to have a greater affect on EGT's. EGT's can get up even with lower than expected throttle input, well before a plate would start limiting the fuel (unless you have it pulled all the way back). It just seems that people make out that running no plate is some sort of voodoo and its bound to melt your engine down.
Old 01-27-2012 | 03:51 PM
lifer's Avatar
Of course there are other things that effect egt,s and of course we all need to keep an eye on our egt's. You guys that take out your fuel plate always want to make it look like theres no problem and its just like having a fuel plate. Its not and yes you can make big hp, I for one do not want to think about egt's all the time when I am pulling. I like to relax and enjoy the drive. On long up hill pulls I still watch it , just in case. Like I said there are a lot of ways to make hp you just have to pick your poison.
Old 01-28-2012 | 12:17 AM
jayhoo's Avatar
thanks 9812vram thats what i was looking for
collin_bucko
14
12-11-2008 04:14 PM
MikeThomas
03-26-2008 08:55 AM
CL2000
10-20-2007 04:34 AM
mouseguy
33
09-26-2007 06:12 PM
wannadiesel
04-14-2003 08:57 AM
Quick Reply: what would it take to make 350 hp?
