What would cause this?
Old 06-29-2006 | 11:02 PM
BigBully's Avatar
96 model w/ auto trans, Runs like POOOO cold and pops back through the Turbo, Runs half way OK after it warms up but Smokes Blue all the time. Is this thing Toast or is it a pump/injector problem or?
Please help.
Old 06-29-2006 | 11:10 PM
torquefan's Avatar
The 2 things I'd check first are timing (may have slipped badly- it'll run like that if it's about 10 degrees late). And fuel supply pressure (no pressure, bad overflow valve, maybe even plugged filter or strainer.)
I hope it's that simple.
Old 06-30-2006 | 11:13 AM
BigBully's Avatar
Yes me too, I really need to know for sure that it is something simple cause I have a chance to buy this engine for $1000
Old 07-02-2006 | 01:23 AM
BigBully's Avatar
Some one has to have some ideas what the problem is with this engine
Old 07-02-2006 | 08:11 AM
Racer9's Avatar
I'd lean towards timing also.
With it running, pull the dipstick, if it has a lot of pressure, oil, etc., coming out the tube, it's got ring, or piston issues.
Are you saying $1000 for the truck? Take it, its fixable.
Old 07-02-2006 | 09:01 AM
BigBully's Avatar
No not the truck Just the engine, The engine is out so I cant run it now Thats why I need an Idea if iys bad or not.
Old 07-02-2006 | 03:34 PM
mr T's Avatar
Please help.
snap,crackel, pop during cold starts is a sign of retarted timing...get it bumped to 16 degrees.....next thing would be overflow valve......and the most expensive would be injectors
Old 07-02-2006 | 09:02 PM
v8440's Avatar
Run, don't walk and get the engine. A set of new 370 horse marine injectors will run you like $400 from piers-no core charge. If you only wanted stock ones, you could find some used for about 100 bucks or less. I sold my stock ones for $80. The other stuff named is even cheaper.
wilderness
10-17-2006 02:38 PM
06inferno
10-16-2006 10:48 PM
Tree DR
17
04-29-2006 10:21 AM
ratsun
12-01-2005 08:29 PM
bigbaddiesel
11-30-2002 08:17 PM
Quick Reply: What would cause this?
