what tells the trans to shift into first?
Sometimes when im driving in the city, it doesnt shift on its own into first gear. I manually shift it and it goes into first just fine. Is there a sensor or something that tells it when to go into first? Is it the TPS? One of these days ill get brave and tighten the bands up.
Re:what tells the trans to shift into first?
the computer gets signals from the TPS and speed sensor there may also be valve body selenoids that measure presure. If you are talking about when u are slowing to a stop sign and dont come to s full stop the tranny wont shift all the way down to first. Its common not just with dodge but the GM's I've had do the same thing. I wasnever able to make any adjustment that would take care of the situation except for the manual down shift...you may be able to do something with something like the EMJAY unit. or a VB modification...
Dan
Dan
Your 97 truck has an electronic governor, which can do stuff like this at times. There are two components on the valve body, one of which is the likely cause. One is the pressure transducer, and I believe the other is the governor pressure solenoid. It is hard to diagnose without the right equipment.
Since I have had my valve body out and installed a shift kit I managed to slightly cut one of the o-rings connecting the valve body to the wiring harness. ATF on hot days will seep into the plug and will not allow it to go into 1st. Clean it out with contact cleaner and comes back. Just something to check. Lon
The two most common problems with not finding first gear when the vehicle drops below 18 mph are the throttle position sensor not recognizing a closed throttle, and the throttle valve cable being slightly misadjusted.
Thats a couple of things for me to check. I plan on taking off the trans. pan one of these days to adjust the bands. Ill look at that connector while im there.
hoot
32
06-11-2008 12:36 PM
4x4not
39
01-29-2007 05:54 PM
00turbo
06-16-2004 08:26 AM
