what kind of HP can I expect?
these numbers might be a little high. with a stock turbo you can only clear up so much fuel. if you add more fuel past the efficiency point you are "putting out the flame" and losing power. saw it happen first hand, person dynoed, swapped injectors, dynoed again and lost 40hp. tuning is key and the timing should really help up top.
Just from experience, I put down 330 with stock 215's and stock HX35 running around 38psi boost. I was thinking with the GSK and few other mods you might get another 20 ponies out of it. I haven't hit the rollers yet with the stuff I changed out.
68rs327
07-24-2011 06:48 PM
Totallyrad
07-19-2011 07:41 AM
nasty01cummims
05-23-2009 10:24 PM
BrandonB9
07-31-2008 03:07 PM
clydesdale6
14
01-22-2003 06:10 PM
