what determines 12v hp ratings 160-215?
Old 04-06-2008 | 03:46 PM
Tate's Avatar
Originally Posted by Skip H
My motorhome has pump #884 and appears to be a 160hp pump - the engine is rated at 230hp. When I filed down the bump out off of the plate, It looks like a 160 hp plate. Can anyone can figure why it is rated at 230hp?
What makes it look like a 160 pump? My 175 and 215 pumps look identicle. The barrels, cam, delivery valves, plate, plate position could all be different from a dodge engine. As well as injectors. Lots of things that will look externally the same that are internally different.
Old 04-06-2008 | 10:13 PM
LOP223's Avatar
I pulled the engine apart today. The good news is that it does have piston squirters. The bad news is that three of the pistons are cracked anyway. So much for a good deal!
Old 04-07-2008 | 12:10 PM
12valvesmoke's Avatar
ouch... that was a horrible deal
Old 04-07-2008 | 04:39 PM
xzaq103's Avatar
I would say injectors. Just like the 24 valve huys have 275hp injecotrs.
Old 04-08-2008 | 11:37 AM
tom25's Avatar
I love my 95 yes it's a dog stock, but afew free mods and it will get with it. but then you will need a T/C and shift kit. I also think the timing is retarded more than the higer HP versions something like 12.5* ver. 14*. but it can be made to run.
Old 04-08-2008 | 08:44 PM
Don Wagner's Avatar
Originally Posted by 94 12valve
They are not the same the 215 pumps have bigger dv's and a more agressive pump cam and they have a notch in the top of the plunger to advance the timing I'm sure there are more differences but these are what I know of.
This response is the closest to the truth, however the upper helix of the 215hp plunger retards timing or shortens LPC as rack travel increases. Many parts are shared between the various models, some are not.
Old 04-08-2008 | 08:51 PM
94 12valve's Avatar
That makes more sence as to why they call it a retard notch thanks for the correction
tmacie
36
09-22-2009 07:31 PM
JohnBer
17
04-01-2009 06:54 PM
redwake9112
10-06-2007 01:39 PM
ewatts2003
23
08-30-2006 06:07 PM
kawi600
02-17-2006 11:03 AM
Quick Reply: what determines 12v hp ratings 160-215?
