What Case Cover Will Prevent The Dowel Pin From Coming Out
I'm looking for the (Gear Case) Cummins part number of the newer design case that will prevent the Dowel pin from coming out......... Thanks.......
Re:What Case Cover Will Prevent The Dowel Pin From Coming Out
I don't know that part # but why spend that money when a 10 cent fender washed will do the trick ?<br><br><br> : Eddie : 8)
TST Products sells a kit for $48 bucks that includes a tab to go over the dowel pin and includes everything else to zip the front cover back together.
The local Cummins Authorized Repair Center performed the KDP fix @ $150 while I drank sodas and watched(3hrs)-it was 92* that day.
There are no revised case covers. Supposedly, the newer covers have tighter pin holes, but I would not trust that to work. Just punch the pin back in, then take a center punch and peen the hole on to the pin, it will hold it forever. If you ever do pull the case for some reason, the pin then comes out the back.
Crimedog
01-20-2004 12:40 AM
