What is the "best" year model to buy
Old 01-06-2003 | 02:59 PM
samtheham's Avatar
Of the years, 94 - 98.5 what is the best year for equiment on the 4 wheel drive and the 5-speed manuel, any problems, I know that new is usually better especially with the 215hp pump but anything else that stands out?
Old 01-06-2003 | 03:08 PM
pappyman's Avatar
Re:What is the "best" year model to buy
The 98 mite be best....if your lucky you'll get the new gear housing and dont have to worry about the KDP falling out
Old 01-06-2003 | 04:22 PM
sdgunslinger's Avatar
Is there a way to tell from the outside if you have the new and improved gear case , or if your old one has ever been replaced ?
Old 01-07-2003 | 10:04 AM
midwestdually's Avatar
98 12valve 5spd
Old 01-07-2003 | 10:19 AM
pappyman's Avatar
[quote author=sdgunslinger link=board=16;threadid=9279;start=0#89042 date=1041891746]<br>Is there a way to tell from the outside if you have the new and improved gear case , or if your old one has ever been replaced ?<br>[/quote]<br><br>I don't know of any way to tell other then taking the cover off and looking to see if its the stepped dowel hole or the open dowel hole...just for my peace of mind I would use the KDP Jig Kit and put a blocking screw in anyways....unless you want to pull the cover and look that would take 2-3 1/2 hrs and gaskets and front oil seal maybe a blocking tab if its moved outward
Old 01-07-2003 | 10:21 AM
Lil Dog's Avatar
The 98.4 12 Valvers are a rare machine. At the 98.5 mark they had the 24 valve come out. In 98 you got the first year of the quad cab also.<br><br>Rare truck, but I would like to find one.. 98.4 12 valve 2500 Quad 5 spd 4X4.... I'll just keep dreamin... [undecided]<br><br>J-eh
Old 01-09-2003 | 12:16 AM
dalton4's Avatar
The gear case was changed in 98 with the 24 valve engine or 98 1/2 model. However, Cummins continued to use up the old style cases on hand. Having a 98 model 24 valver doesn't mean you're exempt from having a kdp problem. It has happened to members at the TDR site.<br><br>Jerry
Crallscars
12-18-2014 10:54 AM
RedRam410
02-02-2007 10:27 AM
Badd Dogg Guy19
14
04-14-2005 09:04 PM
dieselminded
08-15-2004 09:25 PM
Patrick Campbell
10-19-2003 09:22 AM
Quick Reply: What is the "best" year model to buy
