what axle lube??
Old 12-22-2005 | 11:50 PM
Ram of Steel's Avatar
what axle lube??
I'm getting my truck ready to pull my new 5th wheel trailer. It will weigh around 16k lbs. when loaded. I am down to figuring out what brand and viscosity of rear axle synthetic lubricant to use. 1996 Dodge - 2500 - Dana 70 - 4.10:1 - Cummins. Any opinions on brand and viscosity are welcomed.
Thanks!
Old 12-23-2005 | 04:38 AM
kd460's Avatar
IMO, since it's easy to get Mobil 1 75w-140. I tow, but not as heavy as you, and experience cold weather, so I run Mobil 1 75w-90. Might have a little trouble with getting the 75-140 (so I have heard) but autozone carries the 75-90 for sure.
Don't forget to get additive for the clutch plates (if you have posi-do a search for lube gaurd), and fill to 3/8 ths of an inch BELOW the fill plug. I used the additive that autozone carries with no problems.
Old 12-24-2005 | 12:02 PM
Thanks. I have access to 75-140 Redline through my distributor and the local stores have 75-90 and other synthetics.
mknittle
03-11-2015 10:47 AM
dssimecek
03-10-2008 04:58 PM
noelnelson
02-12-2005 07:52 AM
EricBu12
21
07-14-2003 11:28 AM
pwabbott
31
12-04-2002 09:09 AM
Quick Reply: what axle lube??
