What is this??
What is this??
I was changing the fuel filter and while I had it off, I noticed that there is a unit that bolts to the engine block with the same bolts as fuel pump, and it is connected by a rubber hose. It has 2 separate electrical connectors going to it.
Anybody know what this unit is and what the purpose of the 2 electrical connectors are??
I found the top connector totally burnt off the unit. So it seems something is wrong with it.
Thanks.
Thanks.
It's the fuel heater and also contains a cleanable pre-filter screen. The wiring harness and heater element are availible seperately from Cummins, price isn't bad. I have the part numbers at a different computer, can post later.
I kind of thought it was some type of heater. Are there 2 different heating elements in the unit? There were 2 connectors plugged in it, that's why I ask.
I called the local Dodge *******, and they want $250 for the complete unit. I don't think it can be ordered as parts either. Not sure on the harness though.
I would appreciate the p/n's - thanks!
As promised, here's all the parts for the heater, you probably don't need all of them. From Cummins
heater element upper quad ring 3834185-s
heater strainer kit 3845400-s
heater element 3907766-s $35.18
cable harness 3843722-s $49.39
