water pump,T stat question
I am going to replace my radiator due to it rotting out from the outside, Should I replace the water pump and T stat they are both original. I have no overheat or underheat issues and it dosent leak. The only reason I am thinking about it is because I will aready be in there.
what have you all seen after 200K miles.
Thanks
Mike
Thanks
Mike
the water pumps are known to last 300-400K+
I was wondering the same thing when I did my KDP, t-stats seem to go a while too.
on the JD tractors I buy a rebuild kit that has new impeller, bearing, seal and gasket.
