W250 turning over but not getting fuel to start.. Help!
Truck was running fine and one night i ran in a store and left truck idling, upon my return truck was still idling normal. Got in and when i put it in reverse it just bogged down. Put it in park and it idled back up a little, tried again and got the same result. Turned the truck off and checked oil and the plugs on my injection pump and it was all good. Tried to crank truck and it would turn over and hit but wouldnt fire. Making a sorta scratching noise too. Tried changing fuel filter and that didnt work. Cracked an injector line and it was getting fuel. Maybe the fuel shutoff relay or solenoid?
Pull the sol and remove the plunger and spring put the sol back in less the plunger and spring if the truck starts the sol is bad. if the relay was bad the truck would have started when you hooked the sol to the bat so thats not it.
flyfisher123
177
08-10-2015 12:39 PM
