Vulcan Draw Straw
Vulcan Draw Straw
Does the Vulcan Draw Straw work on 12 Valve diesel
http://www.vulcanperformance.com/ser...2%84%A2/Detail
Its says 98.5 and up however it seems I have seen were others with older trucks have used this.
Dave
Dave
I was just wondering the same thing.
The other day my return at the fuel tank fitting failed and was leaking, I couldnt get it off so I was able to get a hack saw blade in there and cut the metel pipe just after the bend and use a short piece of hose slid over the steel pipe and plastic tube. Its suppost to be just a temp fix.
According to this the only differences in the fuel tank module is the electrical connector?
http://cgi.ebay.com/ebaymotors/dodge...spagenameZWDVW
So if this guy is correct, it should work on my 12 Valve? Can anyone confirm this before i order it?
Just got off the phone with Vulcan and they said the draw straw is not just good for the 98.5 and up but is the same for the 94+ 12 Valves.
So all is well.
Thanks
Dave
So all is well.
Thanks
Dave
Nightcrawler50
03-22-2008 02:55 PM
afoulk
08-11-2007 09:25 PM
MARKY MARK
02-24-2007 10:51 AM
