Voltage Regulator
Old 11-30-2007 | 01:14 PM
CaptainChrysler's Avatar
I would say if the tach works the ESS is working too.
Old 11-30-2007 | 08:44 PM
joker_800watts's Avatar
nope your ESS is fine if your tach and alt works
but my problem is mine don't work LOL.
Old 12-10-2007 | 04:27 AM
ChrisM55's Avatar
Just wanted to touch bases and let you guys know how it is going with the external VR.
My charging system has never worked so good!!! I get a good 14.25 -14.75 volts depending on how cold it is (yep, never heard that one before but it is true. THE colder it is the more volts I get!) and my lights seem to be brightter!!
Chris
Old 08-19-2008 | 02:08 PM
victoroneill's Avatar
The external regulator costs $16 to $20 and it takes two wires and a ground. I taped onto the ASD feed for the + and one pin and cut the K20 from the PCM for the other pin. With the PCM I was getting 16.5 volts and it is now reading 14.7 volts. Only problem is the check engine lite stays on. I think the PCM is looking for the alternator.
Old 08-19-2008 | 02:51 PM
Haulin_in_Dixie's Avatar
What vehicle is it? Same system works with any of the "dumb" alternators... Caravan, Dakota, etc. I have not seen the ce light stay on with any of them.
Old 08-19-2008 | 06:59 PM
dozer12216's Avatar
Beware that aftermarket regulators are less than great. Many are not temperature compensated and are dirty with electrical noise. Suggest finding a OE regulator in salvage yard. JMHO
Old 08-19-2008 | 10:41 PM
Interesting, find a 20 or 30 year old vehicle and use the regulator? None of them were temperature controlled. I am a ham operator and never have had electrical noise from the regulator, the alternator is a different story. The last one that I purchased for my Dodge came from Advanced Auto and cost $7.59.
TurboAZ
08-27-2013 09:26 PM
Cooter02
10-18-2004 05:20 PM
Monty
09-09-2003 08:04 PM
freeloader
03-28-2003 09:00 PM
hellotbone
10-09-2002 02:20 PM
Quick Reply: Voltage Regulator
