Vacuum pump seal kit
check out this site www.fixinrams.com
If you can reuse your o rings ( I was able to) you can get a seal from an industrial suppy house like Kaman, etc. The seal you are looking for should be made of Viton material an is 28x38x7 in size. Should run you about $10.00. You can check with these folks to find a distributor that is close by.
International Seal
In case you don't have them here are great directions for the repair.
Vacuum pump seal
Good luck, Frank.
International Seal
Vacuum pump seal
Good luck, Frank.
If your a TDR member look up member ID CPFF. I believe he was the first to develop the seal replacement kit. Didn't cost too much neither - from memory something like $30ish.
jimbo486
05-08-2016 06:07 PM
jragan
09-05-2007 11:04 PM
