vacuum pump Broken?
vacuum pump Broken?
I removed the vacuum pump and power steering pump so i can reseal the vacum pump. after removing the setup i found that the mounting tabs where the ps pump mounts to the VC pump was broken on the engine side? can anyone tell me why it was broken? did some one put it on wrong? was it to tight? Does it have a brace that should support it? has this happen before? I have no clue just a little upset that i have to buy a new pump now! and i dont want to make the same mistake!
Thanks for the help!
Eric
Eric
While I dont have the answers to your questions you might try looking on this website or perhaps even better call Pete Gould and ask him. And you might look at his stuff to use as a parts source as well.
http://www.fixinrams.com/
They break when someone doesn't get the tabs lined up correctly and forces the PS and vacuum pumps together with the bolts.
Probably been broken since you've owned the truck.
www.fixinrams.com will fix you up without having to replace the pump.
jimbo486
05-08-2016 06:07 PM
wvopowered
04-14-2010 09:17 PM
Nutcase
07-13-2007 08:08 AM
Jim Dynomite
02-11-2006 12:56 AM
