Uhm...Torque converter bolts?
Last week I blew the input seal on the trans, either that or a seal in the converter. Lost lockup right before that, it's been on its way out for quite some time now so I figured I'd put a 5 spd in, since I found a few at a local place for a good price, 500 for a stock with X miles or 1200 for reman, complete less clutch and bellhousing adapter.
So I pulled the tranny yesterday, which went considerably easy except I can't for the life of me figure how I'm supposed to take the TC bolts out. Any other tranny I've worked on there is a plate on the bottom that reveals the heads of the bolts, at least enough to get a wrench in there. Right now I have the TRANNY OUT, starter out, and the converter is still bolted to the flywheel. How the heck do you get a wrench in there? A crows foot is too short, regular wrench is way too long, even a stubby was useless to me. Am I missing something? I don't even see enough room to back the whole bolt out anywhere. The bellhousing adapter has a lip that is flush with the front of the flywheel, if that makes sense.
Worst case I guess I get the sawzall in there and cut the nuts right off, but I'd like to keep everything intact if I can help it. Any help is appreciated.
wyattearp29
11-22-2009 05:18 PM
maddog1927
07-19-2007 08:05 PM
