Two or Four-wheel ABS?
Old 02-13-2010 | 05:57 PM
400Magnum's Avatar
How do I determine if I have 2-wheel or 4-wheel ABS brakes on my truck?
Old 02-13-2010 | 09:05 PM
lifer's Avatar
I do not think they had 4 wheel abs in 96 for the dodge trucks.
Old 02-14-2010 | 11:23 AM
infidel's Avatar
4 wheel ABS was an option, both my 95s have it.
Open the hood and look up, there should be a sticker that lists all your vehicle's options.
If there is a box with tubing and wiring going to it to the rear of your underhood fuse box then you have 4 wheel.
Old 02-14-2010 | 02:06 PM
Hodge's Avatar
You can also look at the inside of your front wheels. If each wheel has a toothed ring on the inside of the wheel, you have front abs, in conjunction with the rear abs.
Old 02-14-2010 | 11:08 PM
MrKen's Avatar
When you put the truck in 4x4, does the abs become disabled? I thought I read that somewhere. My 94 has front & rear abs.
Old 02-15-2010 | 08:27 AM
patdaly's Avatar
If you have the original hood, 2 or 4 WABS should be on the sticker.
Old 02-15-2010 | 09:58 AM
dguru's Avatar
They used the "toothed ring" on non ABS as well. Non ABS does not have the sensor or wires in the spindle though.
Old 02-15-2010 | 11:36 AM
400Magnum's Avatar
Thanks for the info guys. I will check the sticker under the hood first, and then verify it by looking for the stuff Infidel mentioned. I assume it's the original hood, nothing to indicate its not.
freshmeat
05-26-2010 07:35 AM
WHISTLINTURBO
06-28-2009 12:58 PM
waam
01-04-2003 06:53 PM
Quick Reply: Two or Four-wheel ABS?
