Turbo wheel upgrade for 1998 12V?
Does any one make an aftermarket turbo wheel for a 1998 12V with stock turbo? Thanks
I have to get a new one and would like to upgrade if there is one out there like a wicked wheel for a powerstroke?
http://www.gillettdiesel.com/HXUpgra...0mm8blade.aspx
this is where i got mine acording to the priceing list its 75 dollars cheaper than htt and its an 8 blade wheel dont really know what the diff is btwn 6 blade and 8 blade is as far as performance wise i also went with a 14cm2 non-wg exhaust housing and what a diff. i did both mods the same day so i cant tell u which one is the more impressive of the two but with it set this way egts so far are no longer a problem i just tested it out this weedend 100 deg day 20ft gooseneck with a bobcat 864 track loader on the back upand down hills just rolling along at 70mph in fith gear and i was about 900 degrees when i was at close to 1300 and i couldnt even go to fith gear i had to stay in fourth b4 this swap empty going 70 with less thatn 5lbs and 2100 or so rpms i only run 400 -500 deg on a 96 deg day imo the best 500 bucks i have spent yet
i also have straight 5" exhaust
rynojr4644
05-18-2009 02:41 PM
ddestruel
04-06-2005 12:26 PM
