Truck starts and then dies????
Ok the other day i had left my dome light on, so I jumped the truck. Got it started ran fine. Went to turn it off and the key went off, radio, ac etc went off, truck still running. I opened the hood wiggled the wires going to the batteries and the wires to the fuel soleniod. The truck finally died.
Now I went to drive it today, it would start run for a second or two then die. Start right back up and then it would die again.
Is this just the old wires that are in the battery cable or what is it???
Thanks in advance.
Thanks in advance.
Check/Clean Battery Connections.
Check/Replace Fusible Link (Blue Wire at Battery)
Check/Replace Fuel Shutoff Relay & Solenoid
This dude sells all the stuff to fix it...
http://fostertruck.com/dodge/default.htm
twisselman1968
09-09-2006 11:55 AM
Magnum Fatboy
07-22-2006 08:53 AM
