Truck starter
Truck starter
Turned the key and the starter just goes clunk. Seperated the batteries and one showes 12.39 volts and the other showes 12.40, should be enough to roll the beast over. I have over 100,000 miles and live on a dirt road so guess it is time to pull the starter and clean any crud inside up. I did clean the cable connectors on the stater selinoid all ready.
??? Question is what do you call those funky studs and what size socket do I need. they look like a star or torx bit.
Thanks
;D Al
Thanks
;D Al
Re:Truck starter
Would be a good idea to open the starter solenoid and check the contacts. You may have a lot of wear with over 100k miles. New contacts can be puchased at a local auto elect. shop. A clicking sound with no starter turning is one of the main indicators of worn out contacts. Continued use can lead to the solenoid hanging up in the start position and frying wiring and relays.
Jerry
Jerry
Re:Truck starter
[quote author=redramnc link=board=16;threadid=18048;start=0#msg171384 date=1060658107]
For solenoid contacts go with LarryB's set - thicker than stock, carry more amperage without heating - plus he advertises on here.
[/quote]
I just got me a set and they are all that is advertised.
Good investment!!
: Eddie : 8)
[/quote]
Good investment!!
: Eddie : 8)
FMB
11-14-2010 09:09 PM
12valvesmoke
06-12-2009 09:46 AM
buckman361
11-13-2008 09:54 AM
99DodgeGuy
01-10-2008 08:00 PM
