Truck no charge-y!
Old 08-20-2008 | 10:44 AM
  #31
Twisted Shifter's Avatar
Also, from what I am reading on my wire diagram .... Pin 20 and 57 are the pins on the PCM. I pulled the block from the firewall to check continuity from the block to the Alt. I have continuity from pin 57 to one side of the alt field wire but nothing from 20 on either field pin. I tried this both with the key on and off. Does this mean I have a broken wire?
Old 08-20-2008 | 03:41 PM
  #32
dozer12216's Avatar
CrusingRam - A post from long lost. Where have you been? Figured died and gone to electricians heaven. I don't have a 98 service manual to check wiring so defer to someone who has correct manual.
Old 08-21-2008 | 01:50 AM
  #33
I found it. some how, have no idea .... the green wire (#20 pin)that comes from the PCM directly to the alternator was broken inside the black box that hooks to the alternator. I but the box off and ran the wires individually and all is well..... Thank you for the input.
Old 08-21-2008 | 01:57 PM
  #34
dozer12216's Avatar
I tell everyone the PCM is not that bad a villian. Alternator and wiring are main failures, just as you found out.
Old 11-07-2010 | 08:54 PM
  #35
CruisingRam's Avatar
Well, reviving this one from the dead- about to do the same mod to a 93 Chrysler imperial!
Old 11-23-2011 | 09:08 PM
  #36
Bump
mkozlows
12-14-2014 11:33 AM
Travs94Ram
06-16-2008 05:05 PM
charger7022
12-11-2007 07:52 PM
getarealjob
09-29-2006 11:17 PM
bish777
07-15-2003 10:50 PM
Quick Reply: Truck no charge-y!
