Truck ate some brake fluid?
I was driving in town and all of a sudden my brake pedal had to be pushed down MUCH farther to activate the brakes...
They did still work though. I have been running DOT 5.1 fluid and it was topped off about 2 weeks ago. I checked it when I got home and the resovoir was well below the ADD mark... So where did the fluid go if I cannot find any obvious leaks down by the calipers?
Also, the master cylinder has been replaced not too long ago by the previous owner.
Thanks!
Thanks!
Originally posted by timeagain
Try your antilock brake mod. & typ 5 fluid sucks up water like a sponge!! I used it in my bike once, had to replace the everything.
Originally posted by fschiola
Had a tech friend tell me just the other day that DOT 3 and DOT 5 are not compatable.
What would the fluid type have to do with my fluid dissappearing?
Just filled the container to the FULL mark with DOT 5.1 again.. Pedal still requires a LOT of travel to get brakes. Brakes work well though when fully depressed.
Since the fluid was run so low, is it possible I need to bleed at all 4 corners?
Thanks
Thanks
Originally posted by 2500CTD
I would bleed them, and check the rear drums. They might need adjusting. Too much play in the rear drums will cause the pedal to drop. As far as lost fluid
Thanks for the info.
Originally posted by Bobcat698
Hmm... That wouldn't be my problem.. I have rear disc brakes....
Found problem. Right front caliper where break hose connect decided to spring a leak.
It seems every time I fix a leak on this truck, ANOTHER ONE springs up
PaulDaisy
14
07-13-2007 07:13 PM
Dave88LX
08-16-2005 09:02 AM
Ballbearing
02-15-2003 08:18 AM
