transmission question 1993 Auto??
I just purchased a 1993 dodge cummins turbo diesel. Its an extended cab automatic dually. When I was driving it home the transmission felt like it was trying to downshift between fifty and sixty miles an hour. I was wondering if anyone might know what the possible problem could be? It seems to shift smoothly through all of the gears and will drive at seventy fine. I was going to change the transmission fluid and filter as soon as I can. Any help would be appreciated!
The band adjustment should be for a 46rh
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns
* Rear Band - Tighten to 72 in-lb, back off 2 turns
