Transmission Jack for 47RE?
Old 03-20-2008 | 04:29 PM
offroad's Avatar
Anyone know what a 47RE weighs with torque converter and transfer case? I'm looking at some jacks and would like opinions please. I don't want to do this for a living just something that works good and doesn't break the bank.
Converts a floor jack to a tranny jack:
http://www.harborfreight.com/cpi/cta...emnumber=95640
450lb Capacity:
http://www.harborfreight.com/cpi/cta...emnumber=39178
800lb Capacity:
http://www.harborfreight.com/cpi/cta...temnumber=3185
2000lb Capacity:
http://www.harborfreight.com/cpi/cta...temnumber=4075
Old 03-20-2008 | 05:14 PM
Troutstrannysvc's Avatar
The 3rd one you have linked is the one we use.
Not sure on exact weight, but I'd recommend unbolting the transfer and just dropping it before you drop the tranny.
Try to find a junk tranny pan and slit the 4 edges so it folds a little, and drill two holes and bolt it on top of the jack, really helps for the tranny to sit in!
Old 03-20-2008 | 09:16 PM
offroad's Avatar
Originally Posted by Troutstrannysvc
The 3rd one you have linked is the one we use. Not sure on exact weight, but I'd recommend unbolting the transfer and just dropping it before you drop the tranny.
Thanks, I looked at that one today and it looked pretty good.
Old 03-20-2008 | 11:50 PM
Deezel Nate's Avatar
The trans isn't all that heavy.. well at least light enough that I can carry them around by myself. I would guess maybe 250lbs without the convertor.
T Case is maybe 45lbs for the normal one, and dunno on the HD... that one is a beast!
I use a jack like the one in the last link.
Old 03-21-2008 | 09:16 AM
TreeFarm's Avatar
I never trust Harbor Freight's weight ratings. I sometimes think they run dozens of units through a destructive test and pick the one that failed at the highest value for their published rating.
Old 03-21-2008 | 10:46 AM
JD730's Avatar
The 47RH that I just weighed is 170lbs without the converter. The whole operation with T-case and converter might be 250lbs.
Old 03-21-2008 | 11:04 AM
justme-'s Avatar
It's not so much the weight as the balance- If you don't have a tranny jack or adapter drop the t-case so the trans will balance better otherwise, keep em together and save the work.
If you only do it occasionally, or once a jack or jack adapter is not necessary. I've done a couple with just a floor jack and some wood- you just have to be careful of the pan.
BTW, a motorcycle/atv jack works well in a pinch too!
Old 03-21-2008 | 01:20 PM
It is SO much easier to re-install with the proper jack though. You can adjust the plate to tip the unit correctly and get it in there with no fuss or injuries.
I have put a few transmissions in by hand before... not fun!
Old 03-21-2008 | 09:50 PM
offroad's Avatar
So, is the balance point on the pan or farther forward? I have put a drain plug in the pan on my 47RE and I don't want to cause leaks by putting too much pressure on that area of the pan.
Old 03-23-2008 | 02:19 PM
I have a deep pan on my trans and I took it off and put an oil steel pan on so the trans would be low enough to slide under the truck and also not to mess up the good pan. The pan isn't the balance point if you have the T Case on, but just wrap a ratchet strap around the trans and attach to the jack so it won't tip off.
Old 03-23-2008 | 03:38 PM
shorthair's Avatar
I wouldn't do it again but in an old scout I did it by hand & just let 'er drop on my chest while lying on my creeper so my buddy could pull me out, & yes alcohol was involved plus youth.
Old 03-23-2008 | 11:29 PM
offroad's Avatar
Ended up with the 800lb model above.
I put a drain plug in the bottom of my stock pan, trying to figure out the best way to avoid putting too much pressure on that area when I pull the tranny out. Any ideas?
Old 03-24-2008 | 10:59 AM
justme-'s Avatar
If you bought the jack the drain plug will not be an issue- the ears fit the corners of the pan mounting lip on the trans housing- not on the pan itself.
Just be sure to strap or chain it to the jack. And with the TC still bolted on the back it will be tail heavy.
mkinla
04-17-2011 08:06 PM
Munchies
10-19-2006 06:09 AM
usmc2311
02-17-2006 11:26 PM
eswartz
03-16-2005 10:40 PM
phox_mulder
03-17-2003 10:32 AM
Quick Reply: Transmission Jack for 47RE?
