transfercase low gear
Old 11-02-2008 | 08:24 AM
oldschoolshovel's Avatar
my 97 5 speed transfercase will not go all the way in to gear has any one else had this problem. Thank you
Old 11-02-2008 | 05:44 PM
DRam11's Avatar
There is an slip type asdjuster on the shift rod that runs from the transfer case shifter to the transfer case. It may have moved enough to prevent the transfer case from going all the way into low range. Loosen the lock bolt and move the adjuster toward the transfer case. I'm don't know how far you should move it - you'll have to use trial and error.
No guarantees, but I'd give that try on my outfit.
OrangeBlackHD
06-22-2010 07:11 PM
2500TurboDodge
01-25-2005 12:56 PM
slowflyer2112
01-15-2005 11:42 PM
dieselman24
02-10-2004 08:52 AM
sshelly
07-10-2003 11:07 AM
Quick Reply: transfercase low gear
