transfer case question
1994 CTD, 5 speed, 4WD
Is there a transfer case vent hose that runs from the transfer case to the top of the bell housing along the passenger side of the transfer case and transmission?
Yes, it comes out under the stock airbox and has been known to occasionally puke oil on some rigs if you get on the right tilt under the right conditions. Most people will experience at least once and wonder where the heck all the oil came from.
Thanks guys, I spotted it while the truck was on the rack and as you may have seen from earlier post I have been thinking it was some type of vacuum that was disconnected.
Is there supposed to be a vent cap or check valve on the end of it? Mine is completely open.
Originally posted by greasy
My 4x4 shift lever is rattling, wasn't able to find a way to tighten it
any suggestion other than stuffing a glove in the boot?
http://dodgeram.info/tsb/1997/21-12-97.htm
I came out today to a rubber line hanging from under my rig. Ran from a short metal line on the top driver side of the transfer and was hanging loose. Loose end had a 4 inch metal line clamped in with a metal mounting tab. Where does the loose end go? It appears the bolt holding the tab down came loose... Does it vent to the outside?
Originally posted by ride_a_hd
Thanks, Bill!
Now, if the loose end has the metal line still inserted, did it break off or just work it's way out of a fitting?
Thanks, Bill!
