transfer case question
Old 12-27-2008 | 10:00 PM
t.sopow's Avatar
ok guys. after 94 is there a transfer case that comes with a P.T.O. cover so i can run my P.T.O. winch if so wich trucks was it avaiable in or is there any sudgestions on installing one in a 98 or installing a good old 205
Old 12-27-2008 | 10:37 PM
Checkmate's Avatar
don't the manual transmissions have the pto spot???
Old 12-27-2008 | 10:49 PM
caleb keller's Avatar
i think the manual do
Old 12-27-2008 | 10:53 PM
RichN's Avatar
On my 95 with a manual transmission, the trans has a spot for the pto. The transfer case doesn't.
Old 12-28-2008 | 12:08 AM
winkdemon's Avatar
ya , the trany has a spot for it . the cover is the same as the one on the old 205 case ,,,
Old 12-28-2008 | 01:20 AM
t.sopow's Avatar
I was asking about the transfer case because i'm running an automatic transmission boys...
Old 12-28-2008 | 09:42 AM
infidel's Avatar
Problem with the transfer case pto mount is that it's dependent on which gear you're in. On the manual mount it only depends on engine rpm.
The transfer case pto will even go in reverse which can be disastrous in some applications.
If you don't want to move the t-case has to be in N, auto tranny in whatever speed you want, with the manual only the 5 speed has to be in N.
Old 12-28-2008 | 12:54 PM
t.sopow's Avatar
Thanks for the advice on the transmissions and on the T Cases. Here's a little background - I started running a transfer case mounted PTO winch because that's the way the factory did it in 1970 in the power wagon I bought. Then I moved it to my '93 Dodge Cummins 205 transfer case, and the reason I like it mounted on the transfer case is because at idle I have five different line speeds and a reverse. So unless anybody can help me with a transfer case for one of these later model Dodges, I guess I'll have to rebuild my '85 Dodge crew cab or divorce mount a 205 in a '98 auto four-door. Any help would be greatly appreciated.
Old 12-28-2008 | 01:43 PM
torquefan's Avatar
Starting in 94, there were 2 versions of the NP241 transfer case used on Dodge diesels. The light duty was installed in most 2500 trucks. The heavy duty came with the PTO mount, and was installed in most 3500 trucks.
Old 12-28-2008 | 09:56 PM
t.sopow's Avatar
thanx for the info i'll look into the np241 and see what i come up with
Old 12-28-2008 | 11:04 PM
Tate's Avatar
NV241DHD is what you are looking for.
wyododge
08-18-2011 07:48 AM
tjohnson
05-27-2005 01:06 AM
FRANKV569
12-31-2004 01:05 PM
Pike
10-03-2004 09:30 AM
Quick Reply: transfer case question
