Trans temp gauge
Old 12-14-2007 | 11:58 PM
xzaq103's Avatar
Trans temp gauge
Im planning on adding my Trans temp gauge in a few days. HOw do you guys hook it up? DO i drill and tap the pan somewhere? What's the best place to put it? Oh also does anyone have pics of where to put it im still really new to autos.
Chirs
Old 12-15-2007 | 12:16 AM
Random Acts's Avatar
Thumbs up Trans temp adapter
I don't know if it works but when I go to install mine I am going to try this thing.
http://www.genosgarage.com/prodinfo....CUTEMP_ADAPTER
Old 12-15-2007 | 07:48 AM
stirpicult's Avatar
that is for the 03-07s, though.
http://www.genosgarage.com/prodinfo....ber=VULCAN_VTA
that is a better option.
or by a trans pan with the plug already there. i will do this.
Old 12-15-2007 | 12:16 PM
Dr. Evil's Avatar
I would much rather have my tranny fluid to be in contact with the probe. I dont like it.
Old 12-15-2007 | 01:10 PM
xzaq103's Avatar
Im thinking the same thing. Im going to put it in the hot line.
Thanks guys
Chris
Old 12-15-2007 | 05:28 PM
infidel's Avatar
I agree.
The first time I installed a tranny temp gauge used a tee in hot line with both the stock and after market sender. Even though both were in the fluid they weren't in the flow.
Result was both of them read low.
Old 12-15-2007 | 06:02 PM
Ronco95's Avatar
The quick connect fittings on my lines went south a long time ago. I had a machinist make a "manifold" that I could screw the new and old sending unit into. Then, I went to a local auto parts store and had two hydraulic lines made up. The shortest one came out of the trans hot output and hit my manifold. The second one left the manifold and went to the cooler under the exhaust manifold.
In my opinion, you need to monitor the fluid temp coming out of the trans. The fluid will break down when heated above a certain temp and you need to know if your fluid is lubricating or not.
The fluid in the pan has already been cooled and cannot give an accurate temp measurement.
I can watch my gauge and tell if I need to lock the convertor or downshift to keep the fluid cool. When my convertor locks, the temp falls 15* within 30 seconds. Good to know if you have expecatations of keeping your trans alive for any length of time.
Hope that helps,
Ronnie
Old 12-17-2007 | 07:15 AM
macattack_ga's Avatar
in-line
You've see this...
It working for me.
At some point I'd like to replace it w/ this:
http://www.dieselmanor.com/dm_products/DM-CLG2.asp
Let us know what your temps are. Mine seem hot so I take it real easy when towing. Cools off real quick after O/D locks up.
Thanks guys
Chris
Old 12-17-2007 | 10:34 AM
jkretzer's Avatar
i had mine installed in the factory replacement hot line that has the temp port built in, always read great. it is now sitting in my buddys garage since i removed it to install my twins. is anyone interested in it? pm me if you are, i want to get rid of it. mopar hot line w/temp port.
1985cucv
02-18-2010 02:03 PM
mar67655
03-21-2009 05:35 AM
Richpwb
08-15-2008 08:01 PM
djgaston
10-30-2005 03:18 PM
live wire
07-21-2003 07:26 AM
Quick Reply: Trans temp gauge
