Trans service questions
Old 04-06-2004 | 09:33 PM
Tackett's Avatar
I have a '97 2500 4x4 with an automatic, and it's time for a trans service. I have a few basic questinos for you...
1) How much fluid should I expect to drain when I pull the pan (I have a Mag-Hitec deep pan)?
2) I don't think I need any RTV on the pan, but I do have a new gasket. Am I correct?
3) Any tips on adjusting the bands?
This will be my first time inside a trans, and I don't have a way to get to the parts store after I open her up.
Thanks,
Tackett
Old 04-07-2004 | 01:57 AM
LHartman's Avatar
Tackett, as I recall, I think I put in 5 to 7 quarts when I changed mine out. I could be wrong, but that guess is close. I've never used RVT on the pan. I have had problems with the cork gaskets leaking. I always try to use the rubber and have never had a leak problem with them. Adjusting the bands isn't too much of a task, just make sure you have an inch pound torque wrench. There's instructions here on how to do it: Automatic Transmission Band Adjustment
Loren
Old 04-07-2004 | 10:41 AM
infidel's Avatar
Most tranny gurus recommend you don't adjust the bands unless your 1st and reverse gears are slipping. More often folks get things too tight and cause more problems. It's another one of those don't fix it unless it's broke situations.
steelblitzkrieg
10-14-2011 09:19 PM
EClancy
01-16-2007 09:27 AM
dieselbeef
06-12-2006 08:12 AM
Lightman
35
12-02-2004 08:34 PM
bws
06-20-2004 10:56 PM
Quick Reply: Trans service questions
