trans problem?
trans problem?
a friend has a 97 with an auto, he says the cel comes on and starts bucking like it won't stay in gear.. i suggested the tps or trans control solenoid but i don't know..... would there be a code we could pull with a scanner? if anbody has any ideas, thanks in advance
If the cel (check engine lamp) comes on, there's probably a stored code. If you don't have a scanner or have a friend with one (even the cheap ones work OK on the older trucks) go to your friendly auto supply store like AutoZone, Schucks, Kragen, etc. and ask them to scan it for you. My '98 bucked like that when the TC lockup cycled improperly.
Purchase of a scanner that can read and erase codes is a great investment.
Dan
Dan
Les Eid
02-13-2008 09:22 AM
nfsommer
11-09-2007 09:36 AM
djgaston
10-30-2005 03:18 PM
live wire
07-21-2003 07:26 AM
