tranny temp gauge
Old 12-15-2010 | 02:27 PM
rustydeeretech's Avatar
tranny temp gauge
well my gauges came yesterday i have every thing wired up except the tranny temp where is the best place for it to be, in the pan or in the line going to the cooler or some where else ? thanks for the info
Old 12-15-2010 | 02:28 PM
its a 96 with the 47re trans
Old 12-15-2010 | 05:26 PM
rebal's Avatar
in the hot line coming out the trans
Old 12-23-2010 | 02:49 PM
MrRoxy's Avatar
Mine came with just a probe, anybody have a pic of how you made that work. I have had the guage in my truck for two years, but not hooked up because I didn't have the money for a new pan with the bung in it. Any help would be great.
Old 12-24-2010 | 08:31 AM
blackimpala's Avatar
Genos garage has an adapter that gos in the cooler line. Your probe screws into that. I got it on my truck.
Floyd
Old 12-25-2010 | 01:37 AM
thanks guys i found a t fitting up at napa and was able to put my sensor in that i just put new lines on my truck when i did the tranny and there were no fittings on the lines like they said in other posts
Old 12-25-2010 | 07:53 AM
shorthair's Avatar
I used the one from I believe midnite diesel that just clamps onto the hot line so no cutting & no leaks seems to have a pretty quick response.
Old 12-31-2010 | 07:27 PM
wcbcruzer's Avatar
Hot line is ideal but more work. I've got mine in the pan b/c it's more of a filler gauge and it's alright.. needle doesn't move much.
Old 01-01-2011 | 01:32 AM
turfguy's Avatar
what kind of readings would you get if you put it in the tranny line where the threaded hole is for the idiot light sensor?
mar67655
03-21-2009 05:35 AM
DennisT
05-11-2007 08:58 PM
Bad Ramer Jamer
12-01-2005 02:30 PM
ten8fiftyone
03-17-2004 09:16 PM
pappyman
12-29-2002 07:33 AM
Quick Reply: tranny temp gauge
