Tranny temp gauge
Tranny temp gauge
I had a tranny temp gauge in a splice in my cooler line before I upgraded my tranny and cooler lines to the steel 2000 model style steel lines<br><br>I would like to install my gauge again but dont want to cut up my $350 new cooler lines to put a sender in for the gauge...the only port is used by the temp sensor now...I dont think it would be good to tee off at the sensor port because that would take both gauge and tranny sensor out of the fluid stream<br><br>Anyone have any ideal where I can put the gauge sender (into the pan is not an option) to read the hot fluid flow<br><br>.
Re:Tranny temp gauge
You could put a tee in the trans on the inward flow line from the cooler, which would tell you what the temp is after the cooler and the sensor would be less prone to damage being tucked tight to the trans.
[quote author=richard link=board=16;threadid=8852;start=0#85345 date=1041026923]<br>You could put a tee in the trans on the inward flow line from the cooler, which would tell you what the temp is after the cooler and the sensor would be less prone to damage being tucked tight to the trans.<br>[/quote]<br><br>Thanks but that would defeat the purpose of the gauge to be able to monitor high tranny temps
Pappy<br><br>I am not sure if the fluid in the pan is hot or already gone through the cooler. But putting a fitting in the pan is a snap. I have put drains in both my 95's. Pretty easy to do. But, if it has already gone through the cooler then your right, it deafeats the purpose.<br>Gary
Mymaur thanks but as I said puttin it in the pan wasnt an option...its not a true temp...and since I haul heavy at times in the mountains on grades that seem to go straight up I need a place that tells me how hot my trannys gettin and as far as I know the exit cooler line has the hottest fluid...but since I put these D#@m high $$$ cooler lines on I hate to butcher them so soon to put in a gauge sender and was looking for a option that would work better then cuttin into the line ???
I'm interested in your prior setup. I've installed three guages but have not hooked up the Trans Temp Sender. How was your Tee setup & what line did you use.
Thanks
Thanks
I'm no expert, but from my understanding the fluid leaves the pan, goes through the tranny valve body, clutches, etc, and the torque converter last, where the heat is created, therefore wouldn't the pan temp be the "operating temp"?<br>
Ive been thinking of removing the current temp sensor and puttin in a 7k resister to replace it then using that port for my gauge sender...has anyone tryed this...will it cause troubles
I just saw a thread on another forum where someone said to use a 700 Ohm resistor (as opposed to a 7K or 7000 Ohm) to bypass the temp sensor to check if it's faulty. Sorry, I can't find which one you're supposed to use. Maybe someone else here knows. One thing for sure if you bypass it, you'll disable the automatic 4-3 shift function when trans temp gets too high. Good luck.
DennisT
05-11-2007 08:58 PM
Bad Ramer Jamer
12-01-2005 02:30 PM
spaman
04-22-2004 11:02 PM
ten8fiftyone
03-17-2004 09:16 PM
