Tranny question
Old 07-06-2007 | 09:51 PM
Zorba's Avatar
Tranny question
On my 96 12 v if i leave it sit for a couple of days and start it up in the morning , let it idle for a couple of minutes then put it in drive to take off it won't move, then if i put it in nuetral and rev it slightly for 1 min and put it in drive it takes off and runs like brand new the rest of the day? what's up? Tranny doesn't slip and sounds good !
Old 07-06-2007 | 10:03 PM
HL649's Avatar
The torque converter will drain if you let it sit for a while. You are filling it back up by reving it in neutral.
Hope that helps.
Old 07-06-2007 | 10:29 PM
TB1's Avatar
TB1
Mine was doing the same thing. I changed the oil and filter have had no problems since then. worth a try unless you have done it lately.
Old 07-06-2007 | 11:09 PM
toy4xchris's Avatar
my 95 had the same problem it was supposedly due to a check valve that dodge later realized they needed to put in. so reving or letting idle in neutral to get the tranny to pump the fluid back through the system is what I used to do.
Old 07-07-2007 | 05:55 AM
Zorba's Avatar
Man you guys are great, thanks for the quick answers!
I'll change out the filter and fluid just for kicks!
Old 07-07-2007 | 10:17 PM
traindrv's Avatar
Mine does the same thing but here lately it might do it after driving it and shutting it off and then driving it again.
Old 07-07-2007 | 11:21 PM
oldblues's Avatar
hi
you can also install a manuel valve from transgo and it will fill while in park also !
Black Dog
12-03-2009 08:18 PM
high bid
08-02-2007 06:08 PM
ezdemon72
14
07-29-2005 10:05 AM
mikie1234
12-25-2004 12:54 AM
silverram323
24
11-09-2003 07:48 PM
Quick Reply: Tranny question
