Tranny noise???
Tranny noise???
I recently noticed my transmission making a squeal when it is cold or i am downshifting fr engine breaking or if i am running through the gears really hard. Could this be a throwout bearing or worse??? ???
Re:Tranny noise???
Generally speaking, if you push in the clutch and you hear a squeal, it is likely the throwout bearing. The pitch should change as you change pressure on the bearing.<br><br>It could be a pilot bearing, but that would squeal more like a chirping bird as you held the clutch down and are stopped, and generally does not make enough noise to be heard when moving under power.
Smkn600CTD
05-22-2012 07:21 PM
Black Dog
12-03-2009 08:18 PM
stuart01
03-27-2004 08:25 PM
dodgediesel4x4
02-25-2004 03:55 PM
