Tranny Doing some Funny Stuff
Old 09-27-2009 | 02:57 PM
thesheriff's Avatar
Lately my truck has been shifting very funky into overdrive. While cruising about 40-55 it will suddenly down shift. I notice the tach has been jumping around also. A few years back I replaced the crank position sensor because it had failed. However, when my crank sensor went haywire, I lost pretty much all of my normal electrical functions. Is there a t.p. sensor or am I possibly dealing with that **** crank sensor again? Thanks for the help.
Old 09-27-2009 | 03:16 PM
wcbcruzer's Avatar
There is a TPS. Here's how you can check it:
http://www.dodgeram.org/tech/transmi...TPS_adjust.htm
Old 09-28-2009 | 09:53 AM
NEWagain's Avatar
Sounds like the TPS to me. Mine bit the dust last week. $125 from Autozone and 3 minutes later problem solved. I know some people have had luck drilling a hole and cleaning the TPS with brake cleaner of some sort, but I didn't have time to try this and honestly feel better with a new one... Do a search for TPS and you will probably find more info than you ever wanted.
Old 09-28-2009 | 10:43 AM
wcbcruzer's Avatar
You can punch the little metal things out of the holes with a screwdriver and enlarge the hole a little so you can rotate the TPS counterclockwise to get the right voltage at idle and WOT. Don't go more than 1.2 v at idle. If your TPS is too far off spec this won't work.
kerry.king
09-03-2015 08:22 PM
pulltilbroke
07-07-2011 11:19 PM
cumminsdriver635
13
08-19-2009 02:15 AM
oldblu
03-27-2007 11:29 PM
brendangsxr
11-21-2006 05:40 PM
